Automotive and Embedded Networks
Can PXI-8531 be a slave node to communicate with Park's IQAN-MD4?
I am wondering if it is possible to configure a PXI-8531 as a salve node using LabVIEW?
I read that CANopen library only supports to configure the module as a master node.
PXI-8531 is a CANopen module. Is there any other way to make the PXI-8531 to be a slave node in the network?
It seems like IQAN-MD4 needs to be the master node...
If anyone has experience on connecting a IQAN-MD4 and a PXI and would like to suggest a better idea on this, it would be very helpful.
Thanks a lots.
(2,719 Views)
As you said, NI-IndCom for CANopen only supports master node.
Generally, the CANopen slave is a sensor or indicator. However, these functionalities are not available for PXI-8531.
Thanks!
(2,692 Views)
