Automotive and Embedded Networks
CF to pcmcia for pocketpc application
So far I have tried a cf-pcmcia converter from the company accurite that uses 5v output and a cf-pcmcia converter from semsons.com that uses 3.3v
I am trying to run the NI CAN/2 Series 2 PCMCIA Card on an axim x5 on one of these adapters. The modules are compiled by Labview PDA and when i run it on the pocketpc I get errors.
So I try to connect the can card to the adapter then connect that to the laptop, here is the error output:
[OSINFO_SECTION]
OS=Microsoft Windows XP Workstation
Service_Pack=Service Pack 2 (Build 2600)
[CURRENT_SECTION]
Section_Index=2
[DRIVER_VERSION_SECTION]
NICANFRM.DLL_VERSION=2.2.0.3040
DRIVERS\NICANPK.DLL_VERSION=2.2.0.3045
NICANPU.DLL_VERSION=2.2.0.300a
NICANTSK.DLL_VERSION=2.2.0.3021
NICANCFQ.DLL_VERSION=2.2.0.3000
NCVI.DLL_VERSION=2.2.0.300e
NICAN.DLL_VERSION=2.2.0.300f
NICAN_S1.NFW_VERSION=20200000
NICAN_S2.NFW_VERSION=20200000
[INDEX_1]
Local_Time= 10/03/2005 14:52:54.112
Err_Status= Status:0xa0fff002-Location:0x20000000-Internal:0x00fff000
Function= ncReadMult-CAN0
[INDEX_2]
Local_Time= 10/03/2005 14:52:54.142
Function= ncCloseObject
[INDEX_3]
Local_Time= 10/03/2005 14:47:00.243
Err_Status= Status:0xb21f0002-Location:0x30000000-Internal:0x021f0000
Function= ncConfig-CAN0
[INDEX_4]
Local_Time= 10/03/2005 14:47:16.377
can anybody help?? what pda's does labview PDA actually run on ??
(5,202 Views)
I've successfully run both DAQ and CAN cards in an IPaq 5550 with a PCMCIA sleeve.
I'm sure you've done this already, but just to make sure...Have you installed the CAN drivers to the PDA?
Most likely I'd say this is a problem with the CF to PCMCIA adapter and not the PDA itself. But that's just a guess.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(5,198 Views)
yes I installed the driver. In using phm device manager it shows as registered but I dont know if the pinout of the NICAN uses more than the 55pins compact flash has.
Can I get a confirmation from a NI engineer.
So you said the ipaq 5555 works, any others?
(5,196 Views)
I don't imagine that a compact flash adapter would be able to handle the CAN requirements; National Instruments has not tested any and they are not officially supported.  I would recommend using a PCMCIA sleeve (see HP iPAQ h5500 Pocket PC series Options & accessories) as Ed has done.
Good luck!
Robert Mortensen
Software Engineer
(5,179 Views)
The 5550 is the only one I've tried with PCMCIA.
(5,171 Views)
thanks for your response.
Have you ran both cards at same time using the dual PC-Card expansion pack? is it possible to run a VI off the ipaq that can use both cards at once?
(5,165 Views)
No, I only have a single slot sleeve.
Ed
(5,159 Views)
