Automotive and Embedded Networks
CAN Frame Channel Conversion Library
Hello, I am trying to use the attached ncd file to read from a Series 2 board via the Conversion library but it's not working. I can load the ncd in Max and it read the channel fine.
What would cause this?
I am using the sample vi USBCANBasicInput.vi. It seems imposible to debug because it uses a dll for everything.
I am using version 1.0.3.
There are extended CAN messages.
Thanks in advance,
Dustin
(9,469 Views)
Followup: More information
It seems to me the most likely cause is the Add selected channels vi is not returning any data in "table handle custer out".
So when the frame to channel read is performed nothing matches and nothing is returned.
Has anyone seen this library work or ran across this issue? Any ideas?
I can use the channel api vi's and everything works as expected.
I was reading some where that the frame dll needs to be in the system32 direcory or this will happen, but I have tried that one.
Dustin
(9,455 Views)
Hi Dustin,
You could verify this by running highlight execution while running your program. This will show you if your hypothesis is correct.
Matt
(9,453 Views)
Matt, yes I believe the DLL is not parsing the selected messages properly so no CAN message is ever matched and thus received.
Could your engineering department look at my attachment and see if they agree or suggest an alternative solution.
There does not appear like there could be anything I am doing wrong, and there does not appear to be anyway to troubleshoot the dlls.
Dustin
(9,422 Views)
Accepted by topic author drogne
Dustin,
It was a pleasure speaking with you on the phone today.
It seems that the problem was in using extended arbitration ID's with the Frame Channel Conversion Library. Here are some examples that show how to use this library with extended arb ID's.
https://forums.ni.com/t5/Archive-TKB/CAN-Frame-Channel-Conversion-Library-USBCANBasicIntput-Extended...
https://forums.ni.com/t5/Example-Code/CAN-Frame-Channel-Conversion-Library-USBCANBasicOutput-Extende...
https://forums.ni.com/t5/Archive-TKB/Obtaining-CAN-Channel-Properties-with-Frame-Channel-Conversion/...
Regards
Peter Flores
(9,410 Views)
Peter,
If this was added to the conversion library example VI's, then it would be pretty hard for most users to get tripped up on it.
I even knew about this trick and didn't think it applied in this case.
Just a thought.
Thanks again,
Dustin
(9,406 Views)
Here is an example I found on ni.com. It has a lot of code, and is for use with a cRIO, but it has LV source code for manually loading a database and converting Frames to Channels.
If you desire more functionality/flexibility, check it out...
Peter Flores
(9,394 Views)
