Automotive and Embedded Networks
CAN Bus Physical Layer Testing
Can anyone recommend any off-the-shelf CAN bus physical layer testing solution that can be integrated with an ATE?
I'm looking for a programmable device for testing things like terminators/impedance, shorts/breaks, detection of swapped lines, common mode voltage, quality level, etc.
It would be best if it communicates via ETH.
I only found Ixxat CANcheck and Gemac CAN Bus Tester 2 (sometimes sold under a different brand). It seems that Gemac can't be integrated with an ATE. All of them are USB-based.
Have any of you ever used these devices?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 1 of 1
(1,417 Views)
