Automotive and Embedded Networks
CAN API errors
Hi All
Here again with some errors
I have a huge application which deals with both channel and frame APIs. My application periodically transmit more than 35 messages to the unit which is under test. But when i start the execution of my application some errors are rising (Not always) and it may be fine when i reexecute the application again. So please help me to make my code error free !! Please find attached error snapshots
error_CAN_1 :- Solution given are 1. Close all other application when i run my application 2. Increase the read que length
I have done both. I Increased read que length to 100
error_CAN_2 :- Same like error_CAN_1. But no idea why its still persist
error_CAN_2 :- Again i didnt get any solution for this error as well
Thanks in advance
(4,506 Views)
Hello Anoop,
For the error -1074388956 when using CAN, this Code means the Board handle is invalid. This could happen if you use not a valid handle because of race conditions within variables or close functions within the code.
For
error -1074388952, you need to specify a read queue length. The error indicates that you got to read frames faster.
Error-1074388699, This error message means, you are in trouble because your code is not able to read all incomming frames fast enough. This leads to a internal read queue overflow and the error occurs. You can try the following: Use the current driver 2.3.2, make the read queue larger and set the frames to read input to 1000, this forces the Read Mult function to read all frames available. If you are using a 2 Port device, try to use only one Port for read mult, because the onboard processor has to serve both ports, this gives him more time. If you are using a Series 1 board, try to use a Series 2 Board, if available. The Series 2 Board uses a larger internal queue for buffering. This may help you.
Regards
Nikhil A.
(4,490 Views)
