Automotive and Embedded Networks
Acquire simultaneously two CAN signal (XNET)
Hi to all!
From a wattmeter i acquire AC_ActivePower (WtmMeas2Val) and DC_ActivePower (WtmMeas1Val). Then i want to trasmit to CAN line both signal.
This is the Database of XNET
The gKERSsync is in one CAN message but the PWtmAC and PWtmDC are in the same CAN message.
This is my VI.
When i acquire the CAN signal i have this strange behaviour
When the PWtmAC signal is trasmitted the PWtmDC is 0 and viceversa. In the other hand the gERSsync is always trasmitted..
If i delete the XNET write from PWtmAC or PWtmDC the remaing signal is trasmitted continuosly.
What can i do!?
(3,194 Views)
I think it is probably because you are clearing the Error -1074384752. If the data you pass to the write doesn't match the size specified in the create session VI it won't transmit any data at all. Stop clearing this error and ensure you are supplying the appropriately sized data to see if this fixes the issue.
Also, why perform two write operations? Why not put both signals into the same session and perform a single write which updates both signals?
Jeff L
(3,170 Views)
I fix the error putting both signal in the same XNET session.
Thanks for the tip!
Also i removed all cancel error on match!
(3,164 Views)
