Automotive and Embedded Networks
ASAP2DEMO ECU Simulator
Hi, has someone already used this ASAP2DEMO to simulate an ECU and worked succesfully with National Instruments Veristand?
Because I've tried but it doesn't work properly and crashes sometimes. I'm curious if someone here has done it succesfully before.
My Channel: https://www.youtube.com/@LV_Lab
(3,279 Views)
The ECUMC toolkit includes a Demo ECU shipping example that works with VeriStand. Both a CCP version and an XCP version that works with TCP/IP. It does require LabVIEW to run but should work in evaluation mode as well.
Jeff L
(3,259 Views)
Yeah I tried that both that is all within the PC, right? Without extra Hardware.
That worked well in my computer but since my real ECU doesn't want to work properly I wanted to use an ECU Simulator
(3,245 Views)
