Automotive and Embedded Networks
ADCS DIDs input/output for data length > 7 bytes
Greetings,
    Does the ADCS support DID input/output with data length > 7 bytes?
Because I tried to add the signal length = 136 for VIN data on VeriStand configuration dialog, but it responded invalid configuration information.
Where could I find the GMLAN example for DID (VIN)?
Description like below,
GMLAN ONLY: DIDs, in the GMLAN context, are static in nature, An example of a DID is vehicle identification number (VIN).
Or I just need to use other library tool to get the UDS data which send with multi frames, like below discussion.
https://forums.ni.com/t5/NI-VeriStand-Add-Ons-Discussions/Diagnostics-CAN-Addon-Custom-Device-suppor...
(1,784 Views)
I want to ask if you have used the Unlock ECU module?
what are requirements for imported .dll file?
(1,680 Views)
