Actor Framework Discussions
Suggestion for Sample Projects: allow User to easily open block diagram
I had a look at the two AF Sample Projects in 2015: "Actor Framework" and "Feedback Evaporative Cooler".   In both cases there is no easy means of opening block diagrams of the running clones.  This will put off someone trying to use these projects to learn about the AF.   My Suggestions:
1) in "Actor Framework", put "Open Block Diagram" as one of the run-time menu options.  Also set the two subActors, A and B, to open their Front Panels by default (with a comment in the code to tell the User how to turn this off).
2) in "Feedback Evaporative Cooler", set the main subpanel to "Allow User to Open Diagram".
Message 1 of 1
(3,786 Views)
