Actor Framework Discussions
Little Bug I've been encountering
Hi all,  Just had a strange bug hit for the third time.  If I have two actor-based projects open at the same time, LabVIEW will sometimes crash.  When that happens and I recover the projects on relaunch, the Stop Core.vi in Actor.lvclass claims to have an error in that it is not part of a LabVIEW class.  Clearly this is incorrect.  I have to open the Actor.lvclass, remove the Stop Core.vi, re-add the Stop Core.vi, and resave everything to make it go away.  Not a huge hassle, but I thought the community might want to be aware of that.
CLAD
(4,559 Views)
Are these on different types of targets? cRIO and PC for example. Or the same type of target?
Casey Lamers
Phoenix, LLC
casey.lamers@phoenixwi.com
CLA, LabVIEW Champion
Check Out the Software Engineering Processes, Architecture, and Design track at NIWeek. 2018 I guarantee you will learn things you can use daily! I will be presenting!
(3,924 Views)
Same target.  Just a desktop machine.
CLAD
(3,924 Views)
I have seen something like this. I have a couple types of targets, PharLap, VXWorks and PC. I don't have multiple projects open as a habit. I have some classes shared on targets (parent/interface classes). I was thinking that the issue might be related to compiling in different contexts.
Casey Lamers
Phoenix, LLC
(3,924 Views)
Pretty sure this is already reported as CAR 496361. I have no idea what the priority is on it, but I've asked that it be worked on for 2015.
(3,924 Views)
Thanks AQ!
CLAD
(3,924 Views)
