Actor Framework Discussions
Is there a way to create a more specific enqueuer for an actor?
To introduce the middle layer:
Every actor class X would have two static dispatch methods: "Launch X as Root" and "Launch X as Nested" both take the actor as input (so you can launch descendant types) and output "X Enqueuer" that has all the necessary Send methods on it.
Every interface Y meant for an actor would also need a "Launch Y as Root" and "Launch Y as Nested" method and a matching "Interface Y Enqueuer", and if you ever wanted to send messages to something that implements both Y and Z interfaces, you'd have to create the combined "Interface YZ" that inherits from Y and Z and adds the "Launch YZ as Root" and "Launch YZ as Nested" methods.
All of that is scriptable.
In short, it adds a second class hierarchy that duplicates the actor hierarchy and the interface hierarchy, but it would prevent messages going to unsupported recipients.
There's a minor problem is what to do with the "Send Batch" or any other message that is added on. This approach rules out those add-ons or any other "create a message that does a composite of actor operations" because you can only send messages that are on the X Enqueuer type. This is a minor problem... we elevate Batch Message to always be part of Actor and then let devs create composite actions by hiding them inside Batch Message (a batch of 1 message where the Do has more complex actions).
The message classes still have to include the downcast check, because you still have to at some point get from a generic actor to the specific actor within the Do method, so there's no runtime savings. (Batch Msg could still smuggle in unintended messages, so the checks still have runtime value in that rare corner case.)
It's a fair amount of additional code. Do you think it would be a better architecture?
Message 21 of 21
(639 Views)
