Actor Framework Discussions
Error 1607 occurred at Actor Framework.lvlib:
Could anybody help me how to fix this problem.
Please.
(6,889 Views)
That looks absolutely correct. I see nothing wrong. Are you sure that's the only call to Launch Actor.vi in this VI?
(6,059 Views)
Yes, I think the only call to launch Actor.vi. But I am not sure. I am beginner in ActorFrame.
(6,059 Views)
Accepted by topic author reteP
Ah. There's the problem. You can't just run the Actor Core.vi. It itself must be launced in order for the self enqueuer to be set up. Use the "Init Actor Queues FOR TESTING ONLY.vi" found in the palettes to do direct testing of an actor without launching it (it is labeled FOR TESTING ONLY because it does not work outside of the debug envionment).
(6,059 Views)
Jop.
The problem solved. Problem was in missing launch.vi what launching actor 😉
(6,059 Views)
