Actor Framework Discussions
Asynchronous Calls in the Actor Framework
In this discussiondrjdpowell mentioned the asynchronous calls in the Actor Framework as an example.  When I was looking for all instances of Start Asynchronous Call, I noticed that they are different from each other - Launch Actor Core mentions a workaround for RT and uses non-strict references, while Time-Delayed Send Message does not.
Is this just a change that didn't propagate to all calls, or are there some circumstances where you would intentionally want strict references wired in the Time-Delayed Send Message way?
Screenshots from LabVIEW 2018f1
(7,841 Views)
Accepted by topic author TomOrr0W
Someone pointed that out to me recently. I've made the same fix in LV 2020 for Time-Delayed Message.
(7,328 Views)
I wish I could get the RT bug fixed, but it doesn't affect many VIs, and I haven't been able to get the team to make it a priority since the workaround exists.
(7,323 Views)
What is the RT bug?
(7,303 Views)
@drjdpowell wrote:
What is the RT bug?
Some sort of root loop priority inversion.
(7,295 Views)
(7,290 Views)
