Actor Framework Discussions
About Install Zyah AF Msg Forwarding Utility
I installed an old version of the Actor message forwarding toolkit before, and recently I found that it has been updated to version V3, and my Labview version is 2020SP1, and then I reported the following error when installing the new version of VIPM, but the compatible version written on the new version is >= 2020, may I ask how can I install this version correctly
(2,741 Views)
Accepted by topic author Morefun
This is probably more of a VIPM issue, but I can offer some suggestions.
  • Make sure LabVIEW is closed.
  • Try uninstalling v2 first.
  • Run VIPM as an administrator.
Also, please be aware that v3 of the forwarding utility is a breaking change. The API is different from before so if you heavily use v2 or earlier, either be prepared to make changes to your code or hold-off on updating until you are.
CLA CLED AF Guild
(2,707 Views)
Yes,it works! Thanks for your suggestion
(2,645 Views)
