Actor Framework Discussions
AF vs Preallocated Clones in S&V
MartinMcD wrote:
I guess I'm missing something?
Did you make the static VI reference "strict"? (Pop up on it and enable the "Strict VI Reference" option.) A non-strict reference cannot be used with the CBR node.
Message 11 of 13
(1,379 Views)
Yes I did make it strict.  In the image attached one way works and the other doesn't as highlighted.
Message 12 of 13
(1,379 Views)
The static VI reference is a static reference to a single VI -- the real VI. If you wire the static VI ref directly to a CBR, you'll execute the same VI everytime. When you go through Open VI Reference, then you're creating a clone VI each time you go through Open VI Ref.
Use the static VI ref if you want every instance to use the same VI.
Use the Open VI Ref if you want every instance to get its own VI.
Message 13 of 13
(1,379 Views)
