Actor Framework Discussions
AF query
@StevenHowell wrote:
I thought I was following the Single Responsibility Principle by having the DAQ actor just read the data from the instrument and then it hands off the raw data to the totalizer which has one responsibility, then the totalizer hands its data off to the averager which has one responsibility and so on.
You're close- IMHO, your actor has two responsibilities. First is the DAQ task, and second is launching the second actor. You could theoretically consider those to be part of the same task (i.e., "make a measurement") but I would argue it's best to break them up into more discrete, independent tasks (i.e., "make a measurement", "smooth the data", etc).
My confusion lies in this:
If the "controller" launches the DAQ, Averager, Totalizer, Datalogger, etc etc. wont the controller have to know the nested actors it launched queues to be able to send them messages? You would have to write the queue of each nested actor into the memory of the controller so that it can send messages "down the tree".
Each actor should only know the enqueuer of its caller and the enqueuers of any actors it launched directly.
If actor A launches B, and B launches C, then A shouldn't know about C.
If actor A launched B, then from A's point of view, B should do everything that A needs it to. Maybe B launches more actors to accomplish that- but it's irrelevant to A. Maybe B has dynamic dispatch versions that accomplish similar goals, but from A's point of view they're all interacting the same (Liskov Substitution Principle, IIRC).
In other words, A shouldn't need to send messages "down the tree", just to its individual branches. Perhaps B will forward that message on down the tree, but that's B's decision to make, not A's.
In my mind that makes the controller depend on all the other nested actors to be able to provide scaled averaged data. Am I missing something?
Yes- generally speaking, when an actor launches another actor, it will know what that actor is, and what messages it can receive. Thus, if Controller launches DAQ, Totaler, and Averager, it will need to retain those enqueuers so it can "do stuff" with them.
One other option is to create a "task specific" measurement actor that only handles the dispatching of other actors. A hypothetical scenario: say you're measuring a voltage, and you have two devices you need to use. One of them is a noisy, low-cost device that transmits data in separate bytes, needing "totaling" and averaging. The other is a fancy multimeter, whose data you can trust implicitly. You can build a HAL to have one override actor that launches DAQ, Totaler, and Averager, and another override actor that just reads the multimeter directly. Thus, Controller just handles the data you send it, rather than having to do a bunch of processing on the data.
In your case it might simplify it to have your business logic actor launch "Measure", which then launches DAQ, Totaler, and Averager. DAQ sends raw data to its caller (Measure), which sends it to Totaler, which sends processed data to its caller (Measure again), which sends processed data to Averager, which sends messages to its caller (yep, Measure again) who finally sends the averaged data upstream to "Controller" (aka Business logic).
One thing I'll note, clearly your code works fine as it is, and therefore it's not "wrong" to do it that way. It's just likely to not be particularly scalable, and since your DAQ actor can only ever send Totaled and Averaged data then you can't use it for non-Totaled or non-Averaged data. This may be fine in your case, but I'd recommend splitting it up because I believe it'll be easier to debug. Just my opinion though which is worth precisely what you paid for it 😉
Message 11 of 16
(2,573 Views)
Thanks again Bert for the response, good info.
One thing that I have always thought was missing with Actor Framework is that when an actor launches a nested, you have to either build an accessor to implicitly write the queue to the caller, or use a cluster bundle.
What would be truly awesome is if an actor launches x number nested actors that it keeps an array of those queues along with keytag name pairs so that the caller could then call any of its callees.
I know that is exactly what happens with the auto stop nested, but you cant use that data because it is not accessible other than in the actor framework library itself, and usually only used by the stop core vi.
Steven Howell
Controls and Instrumentation Engineer
Jacobs Technologies
NASA Johnson Space Center
Message 12 of 16
(2,565 Views)
That wouldn't be too bad to code yourself; you could add a map of [string-enqueuer] to the Actor's private data, then make a new Launch Nested Actor that would insert the nested actor into that map. That way you'd only have to add that code once.
Generally though I do like the hardcoded naming that the current system forces you to use. If I had to look up enqueuers with a String match, then there's a chance one of my methods might have a typo that wouldn't be noticed until runtime. This way, as long as I click the right element in "Unbundle" (or in an accessor) then I know I have the right enqueuer.
I tried to search and didn't find anything, but if you're doing that operation a lot I bet you could make a quickdrop plugin to automate some of that.
Message 13 of 16
(2,560 Views)
+1 to each of what Casey and Bert stated in their posts above.
The general ideas I've gotten about (inverted?) tree-based communication:
  1. The closer an actor is to the root, the more domain-specific it is. Consequently, messages passed between the root and its immediate nested actors also tend to be domain-specific.
  2. The tree structure is similar to an organization structure. The actor at the root (office of the CEO, Principal, Director, etc.) is primarily responsible for the system (company). But, specific responsibilities are delegated down the tree.
  3. The single responsibility at each node (office or individual) of the tree refers to the primary sub-system logic (decision-making responsibility, including delegation) for the data it receives. IMHO, even the CEO of a large corporation (root actor) has a single responsibility: Fulfill the company's Vision by enacting the its Mission without compromising the company's Core Values. It just so happens that, achieving that responsibility may require a large set of nested actors. The devil is in the details. 🙂
  4. Anything an actor cannot (or must not) take a decision on, gets forwarded up the tree (escalation). This escalation need not refer only to exception handling, it could also refer to alternate scenarios of a use case, where a pattern or part thereof (i.e. conditions for the alternate scenario) may be detected by a sub-actor or its delegates, but decision making is left to the actors higher up the tree by design.
My work entails several small-medium projects that are generally unrelated to one another. So, the root actor invariably ends up being named according to the problem it is solving in my customer's domain, E.g. EoLSwitchTester (for End of Line Switch Tester). This way, it generalizes the responsibility to beyond just 'controller'. If I could reduce the number of adjectives to the name I would, though this is subject to project constraints. 🙂
Message 14 of 16
(2,546 Views)
Casey,
I have mapped out my current application on paper to the structure you have in the Msg Fwd Demo.
Going to give it a shot and build an application beside the current so I can reuse alot of the algorithms.
I think this will serve me better and make the application easier to debug and understand. You all were absolutely right the way I structured it was functional, but not reusable or very scaleable.
Will let you know how it turns out.
On a side note, this application is currently running on a Windows PC, but as soon as I finish another project I am working on, I plan to integrate this application into the other and both will be running on a cRIO.
Do you see any potential issues there, resource constraints, etc?
Steven Howell
Jacobs Technologies
Message 15 of 16
(2,498 Views)
If you're talking about using the Zyah AF Forwarding Utility on a cRIO, you should be fine. I know at least one other person using this on the cRIO and after we got some path issues sorted out, it works fine.
If you're talking in general about the Forwarding Utility, I would just give a word of warning and say that though it might be tempting to use it to forward Msgs all around your system, most of the time there are good reasons not to do that. If you haven't already, read the blog and make sure you understand when and when not forwarding of Msgs might be most appropriate.
CLA CLED AF Guild
Message 16 of 16
(2,478 Views)
