Actor Framework Discussions
A little off topic, but...
This isnt specifically in regards to the Actor Framework, however, since AF uses classes heavily I thought I would ask here.
Is there a way in LabVIEW to set the alignment grid size automatically when working with classes, instead of having to do it on a per VI basis via the editor options? It seems that the script when creating VIs through the static, dynamic, or accessors in class, create the VI with the Front Panel and Block Diagram grid size to 12 and 16 respectively.
Call it my ADHD, but this drives me batty! I like to keep them both at 4. Is there a trick to setting this up so that when the script writes the VIs that it will use the settings I choose?
Thanks ahead of time.
Steven
Message 1 of 1
(3,843 Views)
