question about LabVIEW lock-in amplifier design
Hi all,
I'm using myDAQ with NI DAQPad-6259 Pinout to measurement the input signal. and i want to build a lock-in amplifier by labview to measurement the input signal. Does anyone have this kind of tutorials or vedios which can sample help me to build this? I didn't want to use the toolkit but try to understand how to build and why it should be.
Thanks.
(8,406 Views)
Are you using a recent version of Windows?  I want to make sure you can use the DAQpad without running into issues.  It doesn't really have driver support with 64-bit operating systems.
(8,371 Views)
no,not the new version.
(8,361 Views)
Continuing this issue regarding lock-in amplifiers.
I have another question regarding hardware.
Due to the need to move it from one place to another we prefer solution based on notebook and thus USB DAQ-card.
I found this oneUSB-4431, having 4 channels (seems to be working in pseudo-differential input mode, if I am not mistaken), 24-bit resolution, up to 102.4 kS/s sampling rate, delta-sigma ADC and simultaneous sampling mode and +-10V input range - so looking similar to PCI-4474/4472. But it has smaller dynamic range (100dB instead of 110dB), smaller timebase accuracy, and sample-rate resolution and it seems that it doesn't hav antialiasing configurable filters, etc.
I need it for light-measuring applications with signal levels >10uV and I intend to use low-noise configurable AC/DC pre-amplifier (from Femto company) having gain and bandwidth control in order to apmlifier signals before DAQ-card.
Can I use this USB-4431 fro this purpose?
If not, which USB DAQ board can you recommend for this purpose?
Thank you in advance,
RG
(8,183 Views)
You didn't really continue the discussion.  You bumped an old thread to ask a new question. You'll have better luck asking in the multifunctionDAQ forums.  You're asking this question in a forum designed to discuss the myDAQ and myRIO.  These are quite a bit different than what you're wanting.
(8,173 Views)
Ok, thanks.
I will try there.
All the best
RG
(8,149 Views)
