problem deploying code in myrio
hello,
i am trying to deploy my VI ni myRIO, during deployment it is showing "errors in unable to load shared library" and then deployment process is closing.
please help,
thanks in advance,
Mayank
(5,142 Views)
As mentioned in the error you will need to open MAX and make sure that the signal conditioning library (or whatever libraries that you are using) are properly installed on myRIO.
To do so Open Max, right click on your myRIO under remote devices and click Install software. You will be prompted to select from a list of libraries. Select the appropriate one and try the deployement again.
Regards
AA
(5,137 Views)
hey li,
i cant find that install software option..
please can u further describe it?
thanks
(5,135 Views)
You will first need to expand the myRIO and right click on the Software to find the Add/Remove Software option.
(5,129 Views)
