myRio and first FPGA program
Greetings,
I am looking for a very basic tutorial on programing the FPGA on the myRIO.
Most of what I see does not go into the focused detail like your other 'getting
started' tutorials using myRIO.  I want to create some digital logic (clock
signals) and A/D function and I need more precise timing and higher speed than
the RT system offers.
An alternative to a tutorial would be a simple FPGA program that starts with
the 'myRIO Custom FPGA Project' (located in the 'LabVIEW myRIO 2013' start
screen that outputs a 10khz square wave.  Once I see how that is done I think I
can find my way to a solution.
Thank you!
Frank
Message 1 of 8
(8,516 Views)
Check through this: http://www.ni.com/white-paper/3027/en/
It talks about creating waves with the RIO architecture.  It should be a good starting point.
Message 2 of 8
(8,512 Views)
Thank you!  I'm sure the answers are there but I'm getting confused by the seemingly over wellming amout of information.  What I could use to get started is just a simple example of modifing the "myRio FPGA example" to output a simple clock signal on DIOx.
Thank you again!
Message 3 of 8
(8,502 Views)
If that's all you're looking for, you'd just have to add something like this to the example's FPGA VI diagram:
If you're looking for help with things like this, the Example Finder (under help in LabVIEW) is a great place to start. There are quite a few FPGA Module examples that cover these things. Maybe start by searching for PWM (Pulse Width Modulation).
Cheers!
TJ G
Message 4 of 8
(8,499 Views)
Hi T-Rex,
Thank you for your help.  I built the loop as you showed and I get an error when I compile.  Can you explain what I am missing.
Frank
Message 5 of 8
(8,476 Views)
Try starting a program from scratch.  That error makes it sound like you've got more than just the loop they gave you.
Use just that loop and see if the error still exists.  Do you understand how the feedback node works to see what they put together?
Message 6 of 8
(8,461 Views)
Yeah, that error just means that ConnectorA/DIO0 is in use somewhere else... which you don't want. You can change that IO constant to anything else in your application that is not in use, and it should work.
Cheers!
TJ G
Message 7 of 8
(8,449 Views)
Accepted by topic author FHC1234
Thank you nataftw and T-Rex for your time and patience!  I started a program from scratch and I launched my first FPGA program.  Now on to the less challenging step of building some code for my project!
Message 8 of 8
(8,443 Views)
