myDAQ help
Hi, i wanted some help on a project im working on. This involves working on the characteristics of basic components such as Resistors, Capacitors and LED's. I will plot results using a normal power supply by measuring the current going through and plotting a curve on the computer. How would i implement the myDAQ to produce the same idea/ results using Labview. What would improve accuracy between the two?
(3,100 Views)
Hey Moyoomo,
Would you be able to elaborate on what it is you are aiming to do in LabVIEW?
A myDAQ has a number of analog input that you can use to measure voltage.
Using the DAQ assistant you can easily acquire data from a DAQ device into labview. I would recommend having a look at thiat.
Best,
Jelmer
(3,067 Views)
