find latency between analog input and output myRIO
I have connected the analog out pin to analog input pin on myRIO. I have generated the sine wave and collecting it back with the AI pin. But i need to find the time delay between the generation of the sine on AO and reception at AI. Can u pls guide me on how i can do it?
(3,938 Views)
This is the vi that i attempted so far. Pls tell me if its correct or do i need to make some modifications?
(3,919 Views)
      Just see to the attachment, if you want to measure the time this will be usefull to you.
Hope this helps
Kudos welcome 🙂
Certified LabVIEW Developer
Best LabVIEW Programmer @NIDAYS 2015
(3,913 Views)
