device monitor
Device Monitor opened when I plugged in myRIO. I was able to use the options like "Launch the I/O Monitor", then I exited the option. The Device Monitor did not re-appear. How do I re-open the Device Monitor if I want to use another option or even use again the I/O Monitor? Do I have to disconnect and reconnect myRIO? Is this the only possibility?
MCUwiz
(5,192 Views)
Hey CJ,
The device monitor isn't exactly designed to be used repeatedly so reconnecting the myRIO is the only way to make it happen automatically. If you really don't want to do that, you can find the executable in the following path:
C:\Program Files (x86)\National Instruments\Shared\myRIO\myrioautoplay.exe
Hope that helps!
Ty Prather
Technical Marketing Specialist
(5,134 Views)
