control and simulation
I am using cRIO-9024 and I have built my VI using control andsimuation module (including transfer function models).
I am using Analog Output NI 9263 which is also connected to my oscilloscope and I want to display the output values on the scope in real time.
My step size is 0.0001s (10^-4 s)
What timing parameter ie timing source and period should I set so that I will get real time output?
I am confused between 1MHz and Synchronize to Scan Engine options
Please reply
Thanks in advance
(5,526 Views)
Hey Ashish,
You won't be able to use the scan engine with your application. You'll need to look into the read/write controls using a fpga reference.
You can find an example by opening up the example finder from Help>>Find Examples. From there on the browse tab select the directory structure and navigate to CompactRIO>>Module Specific>>NI 9265
Open the NI 9265 Getting Started.lvproj,
Open the project and change the 9265 to a 9263 and use your control code with the read/write node.
Please let me know if you have any questions.
Thank you,
Kyle Hartley
Senior Embedded Software Engineer
(5,498 Views)
