Voice processing using myRIO
Greetings!
We are working on Voice processing using myRIO to implement a system that detects a command given by the user. The command simply is an aplhabet for the ease of implementation. We want a unique factor that distinguishes four alphabet commands. We don't want to convert it to a text output or do anything complex. Please guide us as to how we can proceed.
Thanks in advance and eagerly waiting for help..
Venkatesh
(4,715 Views)
You need to be more specific in your question.  Show us what you have try and tell us where your difficulties are.
Michel
(4,710 Views)
We tried implementing the VI (attached). The problem we face is that the final value obtained in the VI (x*y) is not lying in the same range for a particular alphabet input. Can you suggest to find a parameter that can be used to control the wheelchair when an alphabet command is given to the system.
(4,707 Views)
