USB-6211, multiple samples analog output
Hi Labviewans,
i m using a USB-6211 module. i m trying to perform writing multiple samples analog output.
the followings are the steps i have gone through:
1. create task and virtual channel,
2. configure the 'sample clock' to '5000Hz' and 'continuous samples mode'. i also tried 'finite samples mode'.
3. then i do a write '1D 1 channel N samples'.
the 1D contains the analog output that i simulated.
the problem is that it doesnt work, no analog output is written. please help.
regards
(7,613 Views)
Hi Baobao,
maybe your VI set-up is not correct.  Have a look at a VI I created and see if it generates your waveform.
If this doesn't help send me your code so I can see where you may be going wrong.
kind regards,
Seamus Casserly
NIUK
Message Edited by Seamus C on 11-03-2006 08:48 AM
(7,585 Views)
