PXI 7344 motion controller as a DAQ device for ELVIS
Is there a way to reconfigure a PXI-7344 motion controller with its two 68-pin connectors so as to use it as a DAQ device that would receive the signals from a NI ELVIS workstation. The 7344 has a "motion I/O connector" and a "digital I/O connector". Analog outputs are even possible if I remember well, as well as digital.
(7,747 Views)
The card does has some analog input and outputs. I would check the manual here: https://www.ni.com/docs/en-US/bundle/370838b/resource/370838b.pdf The DAQmx API with a DAQ card is going to be much better than interfacing with a motion card, but you should be able to read off it at the least.
Rahul B.
(7,715 Views)
Thanks for the overall advice. The hyperlink to the pdf returns a "page not found", either for 370838b.pdf or simply 370838.pdf . If you could be a bit more specific about that PDF file, that would be very much appreciated.
(7,711 Views)
Hello!
The period at the end of my sentence got included in the link, hence it became a bad one. This always happens:/
Here you go!
Rahul B.
(7,697 Views)
