Output by connecting input on myrio
Hello guys,
How can I get the output on myrio by connecting input pin to the output pin. Can you give an example code which will do that? i.e if I connect the input pin of the myrio to output pin of myrio it will show something. How can i implement this using a simple code?
(2,830 Views)
Accepted by topic author jazzycool
If you open up the example finder in LabVIEW by clicking Help>>Find Examples, you'll be able to find analog input and analog output examples. If you add those into a project, or look at those examples and implement it yourself similarly, you should be able to see the analog input and output.
C. Weeks
Product Support Engineer
NI
(2,809 Views)
