Need schematic for prototyping board
Hi all,
I have been trying to get the schematic and gerber files for the
prototyping board on top of the NI ELVIS board for a while now with
no luck. Has anyone any idea how to get these?
(10,645 Views)
  just wondering why you need these?
Exactly which part of the prototyping board do you need information on?
If you're looking to get more of them, they can be bought using the following part number :
188429-01
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(10,637 Views)
Hi Sacha,
Sorry for the late reply, I have been away on holidays for a while. I need these files
for a project I am doing in relation to testing ADCs. Since the project involves precision
ADCs I don't want to make connections to the prototyping board. I want to design a separate
board with the same dimensions as the prototyping board. Even a diagram with the connections
on the PCI-style socket of the NI Elvis board would be helpful.
Niall
(10,616 Views)
I also need a schematic for the prototyping board, specifically the mechanical specifications of the edge connector so I can build a pcb for a school project.
WHB
(10,514 Views)
  unfortunately the material involved contains NI sensitive information.
I'm going to have to recommend you speak to your field sales engineer directly to get the release of this information authorised.
If you don't know who this is, please call in on 01635 572410 and ask to speak to sales. You'll be asked for your details, and from then on we can deal with this "off-line"
Sorry.
Sacha Emery
(10,489 Views)
Hi All-
A description of the pin correlations between the PCI header for the NI ELVIS board and the MIO DAQ card (i.e. M Series or E Series) and 68-pin SCSI connectors.
Hopefully this helps-
Tom W
(10,396 Views)
