11-21-2011 04:29 PM
I am having trouble to get the NI mydaq to work with my Windows 7 laptop.
It appears in device manager but the DAQ assistant in Labview does not see any device. Also, the device is not recognized in Measurement and Automation. I have also ran the NI myDAQ Troubleshooting Utility and it said that the device is not recognized in MAX.
I have, however, gotten the myDAQ to work on a Windows XP computer, but it is very important that I am able to get it to work on my laptop.
I have Windows 7 64 bit
Dell D830
NI ELVISmx 4.3
Your help would be appreciated.
11-22-2011 12:37 PM
Hi JaySp,
Can you clarify what you mean when you say that the device is not recognized in Measurement and Automation Explorer, does it show up at all under devices and interfaces?
Also when you see it in device manager, does it have a yellow exclamation mark next to it?
Finally, what version of DAQmx drivers do you have on your laptop? From looking at people who have had similar issues in the past, it seems that updating to the latest version of DAQmx often helps solve the problem.
11-22-2011 03:15 PM
Hi Jeff-P,
The device does not appear at all under devices and interfaces in the Measurement and Automation Explorer. Also, there is no exclamation mark next to it in device manager. The DAQmx driver is version 9.3.5 and is also the same version that was on the Windows XP computer. Is there a more recent version of this driver? If so, where do I go to download it?
11-22-2011
03:24 PM
- last edited on
12-12-2024
03:54 PM
by
Content Cleaner
The latest version of DAQmx is 9.4 and is available here
Please let me know if that helps your problem
11-22-2011 07:41 PM
Updating the driver to DAXmx 9.4 solved the issue. Thank you for your help.
