NI ELVISmx Instrument Launcher Error in Windows 7
I am using windows 7. I have LabView 2011 installed. I also installed NI ELVISmx  4.2.2 but when i try running the Instrument Launcher i get the following error :
Description:
Stopped working
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: niiql.exe
Problem Signature 02: 1.1.0.49153
Problem Signature 03: 4bb1be99
Problem Signature 04: mscorlib
Problem Signature 05: 2.0.0.0
Problem Signature 06: 4d8cdd0e
Problem Signature 07: 12a8
Problem Signature 08: 14
Problem Signature 09: System.IO.FileNotFoundException
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
(6,545 Views)
Hi euniceadu,
I am sorry to hear that you are having this problem.
This error appears to be somewhat generic and seems to be associated with the OS. I have a few questions about your setup, though:
I am wondering, is the device connected to a high-speed usb port?
What exact model of ELVIS device are you using?
Have you already tried restarting the computer?
Have you attempted to repair or reinstall the ELVISmx driver?
Nathan S.
(6,541 Views)
Hi Nathan S.,
   Thanks a lot. I've figured out the problem. After installing LabVIEW SignalExpress 2011, it works okay.
Euniceadu
(6,533 Views)
