MyRio as an GPIB-WiFi interface
Is it possible to implement a FPGA personallity in MyRio to work as a 488 GPIB interface and communicate with an instrument?
Something like:
Computer Host as GPIB Controller 》--- WiFi link --- 》Ni MyRio 》--- GPIB cable --- 》Instrument
or
Computer Host 》--- WiFi link --- 》Ni MyRio  as GPIB Controller 》--- GPIB cable --- 》Instrument
Rodrigo.
(5,611 Views)
Hi Rodrigo,
We don´t have a FPGA personallity to work with MyRIO as GPIB interface, but you can use a GPIB-Serial converter and read your GPIB device as a serial device in the UART port, but we don´t have any example doing it and will not be simple.
So it is not impossible do, but is not simple implement this.
http://sine.ni.com/nips/cds/view/p/lang/pt/nid/203552
http://www.ni.com/white-paper/4052/en/
http://www.ni.com/example/30978/en/
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(5,535 Views)
Thank you Abel.
But if I need a GPIB-Serial converter, it´s better to use a GPIB-USB or GPIB-Ethernet converter without the MyRIO at all.
It would be possible to implement a FPGA personality to work with MyRIO as GPIB interface, maybe using LabView FPGA module. Is there any impediment to implement it?
Rodrigo.
(5,532 Views)
Don´t have any impediment to implement this using FPGA module, but you need implement the 488.2 protocol on FPGA.
Abel Souza
(5,529 Views)
Thanks, it seems a good project.
(5,522 Views)
