MyRIO via WIFI : failed to discovery chassis
Hello all
I'm new to labview , i do have basic knolege but that's all.
the problem is that when i try using MyRIO as an acess point to programme it ,it say the following "failed to discovery chassis" ........but when  i use USB it work very well
just to be clear i use labview 2014 and the hardware is there in NI-MAX
please help Smiley Sad
(5,435 Views)
@Crowned-Clown wrote:
... ,it say the following "failed to discovery chassis"...
What is "it"? Are you connected to the myRIO access point via WIFI?
(5,428 Views)
thx for the quick reply
yes.at first i used usb connection and work normally but with wifi i doen't
i connect my pc to MyRIO directly via wifi and then try searching for remote devices untel then all normal but when i try to add it in my project ===> "failed to discovery chassis"
Smiley Frustrated
(5,426 Views)
i discovered the problem
i juste needed to right-click => connect ....... that's silly but well, someone will need it in the future so i will post it here
(5,411 Views)
