KNRm Real-Time Application Error
Hi, I am using KNRm with myRIO-1950. First of all, here is my project directory.
When I run a VI directly from the computer, the program works fine and the motor will move.
And then when I try to build a real-time application and deploy it to myRIO, the program won't execute after the myRIO restart.
MoveMotor(Remote)VI.PNGThe above program is the same as the first program, the motor should move for a short period of time. I insert the LED blink block and time delay to check the program. The LED do light up, but the program after that won't work, it shows error 61202.
I set My Real-Time Application as a startup. Here is some image for the setting.
I try to deploy another program with the real-time application, which is just LED blinking and some time delay in between. I build the real-time application, set as a startup, deploy the application and restart the KNRm. The program works fine.
(3,022 Views)
(2,895 Views)
