KNR
hello !
can any one help me with this
i try to select file but i did not find it
i need to power on KNR DC motor
(3,975 Views)
Hi!
Thank you for posting to the forums!
Can you provide a little more insight into what exactly you are doing? Are you using an example that you could share the name of or share the code? Are you using any toolkits/modules/drivers for this motor? Where is this FPGA Interface Base.lvclass in your project?
Thanks for the clarification.
(3,943 Views)
Hi
I open an example
DC motor.vi
When I open it it is looking for some lib and I find a shortage in this library and many FPGA lib
What I want is power on a DC motor drive plugged into the knr
I have installed labview myrio
And installing KNR OS 3.1 LabVIEW Software Installer.zip
I re-installed but without interest
You can help me operate this DC motor
sorry for my English
thx.
(3,936 Views)
Thanks for the pictures!
I would check out this forum post: https://forums.ni.com/t5/NI-Labs-Discussions/lt-userlib-gt-FPGA-Interface-Advanced-Tools-cannot-be-f...
It looks like there is an older version of the tools called FPGA Interface Advanced Tools vs the newer FPGA Advanced Session Resources. This project is looking for the older version (FPGA Interface Advanced Tools) which is depreciated but can be found in the link below:
 https://forums.ni.com/t5/NI-Labs-Toolkits/LabVIEW-FPGA-Advanced-Interface-Tools/ta-p/3494081
Let me know if this helps provide any insight.
(3,927 Views)
thank you !
I downloaded the old version of FPGA and it's work
thank for you support
(3,922 Views)
