02-11-2017 06:28 AM - edited 02-11-2017 06:43 AM
Dear all,
We are trying to implement fuzzy logic. We are able to run it on the computer without any problem, but when we tried the same thing on NI myRIO we aren't getting any output. There isn't any error when we run the program on myRIO.
http://forums.ni.com/t5/LabVIEW/How-to-implement-Fuzzy-toolkit-on-the-myRio/m-p/3197951
We tried using the solution given in the above thread. But we don't know where myRIO directory located. And how to access it and use it in our program.
It would be of great help if someone knows how to export/copy the .fs file and our program .vi file to NI myRIO directory or if there is some other solution to the problem.
Any suggestions are greatly appreciated!
Thanking You,
Rinareema
02-06-2019 05:27 AM
you can acces the device drive through a web browser acces (you need to use internet exporer, and put on your device´s IP on the search bar) or you can acces it as a network mapped drive, here you can understand it better with an example
