How to check if all the data is sent to the analog out of myRIO?
I am trying to output an array to the analog out pin of myRIO. I am doing this in a while loop. but the loop keeps on running. pls guide me on how to stop my vi once all the data has been output to myRIO
(4,124 Views)
Can you share the code? Or at leat a snapshot?
Guilherme Correa
(4,121 Views)
It would also help if you could explain what exactly you want to do. You could potentially feed the array into a for loop and auto index into the output function. If you put a wait function in the loop it should go through the array at the specified rate and stop once it has gone through all the values.
(4,111 Views)
