FPGA problems with myRIO
Trying do compile some simple FPGA vis to my myRIO, but often get the attached error from the compiler. I have had parts of vi working temporarily by manually programming everything from scratch again (no copy-paste from other vi), but now the simplest things (two while loops, one with FPGA I/O node and one with FPGA Property node, really really basic stuff) also give this error. This is getting frustrating. What am I doing wrong?
best regards
soeren
(6,878 Views)
....and here we go with the error:
LabVIEW FPGA: The compilation failed due to timing violations, but there is no path information because the timing violations are not of type PERIOD.
(6,877 Views)
Hey Soeren,
Can you post your code.
Thanks!
-Sam K
LabVIEW Hacker
Join / Follow the LabVIEW Hacker Group on google+
(6,869 Views)
Here we go. Fairly simple stuff.
soeren
(6,845 Views)
Accepted by topic author soeren
Hi again ppl
I have now come up with a "solution". It turns out that if I create a new vi and manually (.......yes manually) start placing blocks and making loops I can actually compile the FPGA vi. Somehow copy-pasting loops from one to the other vi makes it malfunction.
Have anybody else experienced this?
.......anyway back to programming
soeren
(6,818 Views)
