Error in Program
We have doubts because when we use a data buffer it should be an indicator but appears as a controller in the VI, we used an example of your page but as I mentioned, the Data buffer appears as something it shouldn't be. Also, there should be a graphic in the Front Panel, but it doesn't appear.
The link from the program we are trying to do:
http://www.ni.com/white-paper/11198/en/#toc1
Also, in the stop from the Startup should be a block next to it, but I don't know how to put that one or the name of it. We are new to Labview but we are designing this program because it looked easy. I'm sending you the VI we did just so you can see that there are a lot of things different.
(6,261 Views)
You forgot to attach the VI.
(6,250 Views)
Hi Gerardley!!
Thanks for using National Instruments Discussion Forums!!  Can you post your LabVIEW project please?  This will give us a better insight of what you have done so far.  In addition, I have a couple of questions for you:
    • Is this the first time you use LabVIEW?
    • Are you familiar with LabVIEW Real-Time?
    • LabVIEW version
    • RIO target
    • OS
Hope to hear from you soon!!
Anuar R.
National Instruments México y Latinoamérica
Ingeniería de Aplicaciones
www.ni.com/soporte
(6,237 Views)
