Electronics Workbench and Layout install problems
Problem Description :
Hello, I have an old,old version of Electronics Workbench and Layout
Personal
Edition Version 5.0c. Ser # EHW-01-05438 and U911385. I have used these
versions on and off since 1998 when I purchased them from Interactive
Image. I
am trying to reinstall it on a windows 98b machine and I get a message that
says, " The Setup program has detected that this disk set has already been
used
by: Lane C Hoyt, EHW-01-05438-5182, It is acceptable for the legal owner to
reinstall the product in order to update an existing copy or to replace a
corrupted or missing version of the program". I then go through the usuall
setup dirctory stuff and then get the following message: " Electronics
Workbench Setup has encounntered an err writing Serial Number information
to
the install disk. Please make sure that the disk is not write protected,
and
that you are installing from the original disk."  The disk is not write
proteted and it is the original disk 1 of 6. I use the program rarely but I
do
use it. Is there ANY WAY to edit a file on the install disk or delete a
setup
file??? How can I reinstall this program HELP!!!! I don't want to spend the
money for a new version when I use it so rarely.
Thanks for any Help yopu can offer,
Lane Hoyt
lchoyt@msn.com
Message 1 of 1
(7,241 Views)
