Controls/Decorations
I looked at a file from the developer zone called "load and append array.vi" . I have slightly adjusted the front panel to exemplify my question. I have attached the file to this question. On the front panel at the upper right is a rectangluar box, this box can be moved anywhere and be placed on a collection of controls or indicators to make the  front panel more beautiful.
I have searched for this control but I can not find it, Moreover, I do not even knowl its name. I have seen it in some couple of tutorials too but I do not know where to locate it, but will like to use it in my program too
I will appreciate any answer to this. I use LabVIEW 8.2 Student Edition, maybe that is why I can not find it
Thank you
Message 1 of 13
(9,864 Views)
It is a simple decoration. It is not a control, because it has no connector on the block diagram.
Look for Horizontal Smooth Box in the decorations palette. 🙂
Message 2 of 13
(9,858 Views)
Thank you Altenbach. I located it from where you pointed
Message 3 of 13
(9,853 Views)
I'm having difficulty placing front panel objects on a "Horizontal smooth box" decoration and I can't understand why. I have finished writing the code in the block diagram but when I drag the front panel objects onto the smooth box they don't appear on it. Is there an explanation for this? How can this be done? I have labview 8.2 as well.
Message 4 of 13
(8,914 Views)
You probably need to change the z order of the controls. Click on the decoration and go to the 'Reorder button on the toolbar.
Message 5 of 13
(8,910 Views)
The options on the reorder button doesn't anything about Z order. See attached VI.
Message 6 of 13
(8,907 Views)
You don't have a decoration on the front panel and z order refers to which objects are on top of what and the order of those objects
(In case you don't know, x refers to left/right and y refers to up/down.). If you actually place a decoration on the front panel and then move one of your existing controls/indicators, you just have to select the decoration, go to the reorder button, and select 'move to back'.
Message 7 of 13
(8,905 Views)
Hi Dennis,
Your suggestion worked but I have another question. I've attached a picture. How do you build the attached front panel? Can you tell if it was built on some kind of tab control?. My main problem is actually the "selected subset" Analysis section. How was the size reduced?. I'll appreciate your help.
Message 8 of 13
(8,873 Views)
If you have the actually VI, it would have been far better to attach that. Attaching an image directly instead of some propietary file format (MS Word) would be preferred as well.
From the image, it does not look like a tab but you never know. Any control/indicator can be resized with the mouse. You just select it and grab the resize handles. You can also display another VI in a subpanel. It could be either or both.
Message 9 of 13
(8,870 Views)
Hi Dennis,
It is an example vi from a tutorial so I only have picture of it. I've attached the block diagram. Perhaps it could shedd some light.
Message 10 of 13
(8,867 Views)
