Can myRIO work as an SPI slave
I am wondering if two myRIOs can communicate with each other using SPI. I have wired them up but the data cannot be transmitted. Can one of them work as master and the other as slave?
Thanks!
Aoyu
(6,306 Views)
Hello Aoyu
MyRIO could only act as a SPI masterThe only way to use the myRIO with your application would be to code this in FPGA. This would take quite a bit of FPGA LabVIEW coding to implement, but in case you're interested, here are a few resources you may find helpful:
Implementing SPI Communication Protocol in LabVIEW FPGA
Regards
Frank R.
(6,290 Views)
