Can NI myDAQ ai0 and ai1 be connected directly with thermocouples to measure temperature???
I am trying to use myDAQ to realize both temperature measurement and digital output.
By reading this page I have learned that how I can create a task for temperature measurement using thermocouple with a certain NI device.
http://www.ni.com/white-paper/14338/en/
What I found to be really interesting is that when I create a task for myDAQ temperature measurement using a thermocouple when my NI myDAQ is connected with my PC, two AI ports ai0 and ai1 both appears in the create task window!!
I never found any information from NI myDAQ manual that "AI0 and AI1" can be connected directly with a thermocouple to measure temperature without using additional conditioning system. But this window suggests that myDAQ can be used in this way, is it?
I am still trying to do it this way, and I'll post some results here again.
I would be really appreciate if anyone could confirm or disprove my guess. Thank  you.
PS:
Attached is the
(7,546 Views)
Attached is the screenshots for "create new task" in NI MAX
(7,545 Views)
I would guess the myDAQ uses comparable hardware to the USB-6008 and USB-6009.  If this is true, you might want to take a look at this:
http://digital.ni.com/public.nsf/allkb/8166630BD6965EEA86256FDD0052E89C
You generally want to look at hardware that is geared towards this particular measurement.
(7,408 Views)
Thank you for your reply.
I actually have a 9213 to do thermocouple measurments. I just want to know, if thermocouples can be connected directly to NI myDAQ it will be pretty convinient for me to make prototypes.
(7,400 Views)
myDAQ spec sheet: http://sukjaro.eu/ELFT-NI-palyazat/myDAQ_Manual.pdf  Look at page 36.  You'll see the ADC is a 16-bit ADC.  You'll also see there are only two input ranges for AI on the myDAQ:  +/- 10V and +/- 2V.  This means the +/- 2V range would offer the highest resolution for you.
4V/(2^16) = or 61uV  That's larger than the voltage response of a thermocouple.  If you look at the absolute accuracy, you're looking at +/- 4.9mV for the +/- 2V range of the myDAQ.  4.9mV is 4900uV.  If the accuracy is only useful within 4900uV and you need a voltage response 56uV or less, you're using a tool that isn't well fit for the job.
Can they be connected directly?  Sure.  But, I definitely wouldn't suggest it.  4900 is 87.5 times 56.  That's a pretty big jump and could lead to some inaccurate readings.
(7,358 Views)
