3 wire RTD connections.
Need help taking a temperature measurement using a 100 Ohm 3-wire RTD on the myRIO.  I know that a wheatstone bridge in some shape or form is used, but I have no idea how to choose the resistors for that or where the wires on the circuit would actually hook to the myRIO ports.  If a sample VI for this hookup could be provided, that would be great.  I’m pretty new to how all of this works.  Got the myRIO for a class and am now trying to use it for side projects.
(5,257 Views)
Hi Vocalict!
I would recommend taking a look at this discussion forum post:
RTD Temperature Measurements using LabView 2013 and MyRio
http://forums.ni.com/t5/LabVIEW/RTD-Temperature-Measurements-using-LabView-2013-and-MyRio/td-p/29220...
While this post specifically discusses 2-wire measurements, the information in the post should still be helpful.  I would also recommend checking out this tutorial:
Taking Temperature Measurements with RTDs: How-To Guide
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1rnCAA&l=en-US
This should help get you started!
Tucker
Applications Engineering
(5,230 Views)
