资源文档分享区
在 Windows Explor 中直接生成新VI
代码和文档
添加附件
Right click on a folder, then create a new VI from the pop-up menu.
Run the reg file to integrate it into your Windows Registry.Then you will see a new item, LabVIEW Instrument, on the right click popup menu New... for all folders.Click on this item, an empty VI will be put on the current folder.The binary data in the reg file is an empty LabVIEW 8.0 VI.You can change the default new VI by changing this binary data.The "Create New Reg Data.vi" can hlep you generate the registry data.A Chinese description is here: http://ruanqizhen.spaces.live.com/blog/cns!5852D4F797C53FB6!2291.entry
NI社区“代码范例交流区”(Example Code Exchange)中的代码范例已获得MIT许可
贡献者
