FIRST Robotics Competition Discussions
Problem building/deploying when using Point by Point filters
I've been playing around with some of the filters in the Signal Processing -> Point By Point -> Filters PtByPt. They work fine when running the program in ram.
However, when I try to build the project, it takes a very long time to build (instead of 2 minutes normally, it takes closer to 20 minutes). During the build process, I see all kinds of esoteric mathematical/signal procesing type VIs being built. It seems that there are many dependencies that only gets pulled in when built, and not when run in ram.
Additionally, when I try to deploy newly built program, it doesn't work. I get the following result.
Deploying Beachbot2008-8.lvproj
Deploying RT CompactRIO Target  (successfully deployed target settings)
Deploying DriverStationLCD.lvlib
Deploying PWM.lvlib
Deploying DigitalModule.lvlib
Deploying DriverStation.lvlib
Deploying Compressor.lvlib
Deploying Accumulator.lvlib
Deploying DMA.lvlib
Deploying Watchdog.lvlib
Deploying AnalogChannel.lvlib
Deploying RobotDrive.lvlib
Deploying ContinuousPot.lvlib
Deploying Solenoid.lvlib
Deploying DigitalInput.lvlib
Deploying AnalogModule.lvlib
Deploying AnalogTrigger.lvlib
Deploying Encoder.lvlib
Deploying MotorControl.lvlib
Deploying Relay.lvlib
Deploying VariantType.lvlib
Deploying Gyro.lvlib
Deploying NI_AALBase.lvlib
Deploying NI_FileType.lvlib
Deploying NI_PtbyPt.lvlib
Deploying Camera.lvlib
Deploying DigitalInputFilter.lvlib
Deploying Counter.lvlib
Deploying NI_FPGA_Interface.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA SPI.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA Interrupt.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA Global.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA System.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA Solenoid.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA AI.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA Encoder.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA Counter.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA AnalogTrigger.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA Watchdog.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA DIO.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA CounterEncoderSourceConvertion.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA DMA.lvlib
Deploying Joystick.lvlib
Deploying FRC Robot Boot-up Deployment (failed to deploy)
Deploying Acquire Image.vi
Deploying Async VI Agent.vi
Deploying Autonomous Independent.vi
Deploying MarsRock.vi
Deploying Robot Main.vi
Deploying RunCompressor.vi
Deploying Send Images To PC.vi
Download completed with errors.
Any ideas?
(11,818 Views)
Hey sciencewhiz,
I wanted to give you an update on this. I've reproduced this issue and I will be working on it more throughout the day. I'll give you another update when I have more.
Sorry about the troubles
Stephen B
(4,192 Views)
I noticed the same problem!
take a look at my thread:
http://decibel.ni.com/content/thread/2087
in my last post I diagnosed the same problem, after a harsh seek for causes.
I think it's a problem with all filters. Not using them would make traction control and accelerometer noise reduction a lot harder.
(4,192 Views)
This has been escalated to R&D and they have been investigating it. So far we might have a work around for you: If you open the build spec, visit the page for exclusions, and check the option to remove unused members from project Libraries, your build time should return to reasonable times.
Sorry for the troubles, I will give you an update when I have more information.
Stephen B
(4,192 Views)
Using the workaround, I was able to succesfully build and deploy.
(4,192 Views)
Are the filters are working?
(4,192 Views)
