01-12-2015 06:09 PM
I would like to know if there is a way to use the VirtualBench API without LabVIEW?
Like using python or something.
Thank you
Solved! Go to Solution.
01-13-2015 07:56 AM - edited 01-13-2015 07:57 AM
We just released version 1.1 of VirtualBench that adds a C API and a bunch of other features, see http://forums.ni.com/t5/VirtualBench/Announcing-free-firmware-update-version-1-1-adds-SPI-and-I2C/td.... With that you could use VirtualBench in your programming language of choice if you write the appropriate bindings.
01-13-2015 08:18 AM
Great!!!!! Thanks!!!
I really need it!.
Excited VirtualBench User
01-13-2015 09:17 AM
Hello Joe,
Also, there is a way to download the firmware without using the application. Because the company network does not allow the connection or drops it.
Thank you,
Jonathan
01-13-2015 09:35 AM
The firmware update isn't strictly necessary to use the C API. The C API should work on your VirtualBench with existing firmware. However, if you want any of the new features to work, then you will want the new firmware.
01-13-2015 09:46 AM
Well, yes, I may not need it now, but seeing the new features it would be nice if we can start checking them out soon.
I see the links for the driver driver/runtime/app but I do not see it for the firmware. It starts downloading it and says something about 3 mins remaining and when it is near the end, I get an error message so, is there a way to download it and then send it to the HW?
Thank you.
01-13-2015 02:39 PM
You're right, there is not a download page for the firmware updates. I've sent you a PM, to work on this offline. We're handling requests like this on a case by case basis for now.
Luke B.
NI R&D
