VeriStand
Sampling at higher rate than the PCL one
Good evening to you all. I'm trying to sample a signal at 100kHZ using a FPGA personality in NI Veristand. I would like to use this samples as an input for a simulink model running at 500Hz. I was wondering if there's the possibility to do so.
Thanks in advance,
best regards
(6,246 Views)
Accepted by topic author Domenico_fed
FPGA data is read back to VeriStand point-by-point. Hence, your model will receive the latest data from FPGA, but not all the points.
(6,233 Views)
Ok, thanks a lot for your answer. It means that we have not to use Veristand....
Regards
(6,225 Views)
This is solvable. In multiple ways:
1) You could use multiple channels to get data from FPGA and in fact serialize them.
2) You can create custom device and use LV Advanced FPGA tools (https://decibel.ni.com/content/docs/DOC-17185) to transfer data from FPGA f.e. by additional DMA channel and them serialize the data on RT part
The drawback is, that you would need 200 channels to do so.
Jiri Keprt
NIE Systems Engineer (RTT&HIL)
CLA, CTA, CLED
(6,212 Views)
Yep, we tried that, and we realized as well the fact of the 200 channels... We hoped there was a better/faster way to do so 🙂
(6,207 Views)
There is no elegant way to do so Smiley Sad
You could use System Definition API to generate channels, and also API to do mapping...
Jiri Keprt
CLA, CTA, CLED
(6,204 Views)
This is possible with NI VeriStand 2012 and later. Transfer the data from the FPGA using DMA FIFOs up to RT and then use a custom device running RT code to read the DMA and publish a "waveform" of the data using the custom device API.
Stephen B
(6,152 Views)
