VI Analyzer Enthusiasts Documents
How to Install and Use a Custom VI Analyzer Test
by Example Gatekeeper ‎04-17-2013 05:31 PM - edited ‎01-30-2017 08:18 AM
Follow these steps to install and use a custom VI Analyzer test LLB:
  1. Save the test LLB in [LabVIEW Data]\VI Analyzer Tests. You may need to create this folder if you have never installed a custom VI Analyzer test before.
    • Note 1: If you don't know where the [LabVIEW Data] folder is on your system, you can find out by navigating to Tools > Options > Paths > Default Data Directory in LabVIEW.
    • Note 2: If this is the first custom test on your system (i.e., if you had to create the 'VI Analyzer Tests' folder as described above), you will need to restart LabVIEW before performing the remaining steps.
  2. Launch the VI Analyzer (Tools > VI Analyzer > Analyze VIs...).
  3. Start a new task and click Next.
  4. Add the folders/VIs you wish to analyze and click Next.
  5. The new test you installed should appear in the Tests list under the <User-Specified> > VI Analyzer Tests folder.
Note that the VIs within the test LLB must be saved in a version equal to or older than the LabVIEW you are using in order for it to be usable in the VI Analyzer.
Comments
Active Participant shb
Active Participant
Alternative to "Note 1": open and run Dflt Data Dir.vi from File Constants Palette.
Alternative to "Note 2": Since LabVIEW 2013, you can also execute execute the Appliction Method Menus:Refresh (see in LV help).
Active Participant
Tests can be placed in subfolders (of [LabVIEW Data]\VI Analyzer Tests). They will be shown in a subtree in test the selection.
Example with folder myTries:
Contributors
