USRP Software Radio
Problem with two USRP
When i use same USRP 2952R for transmitting and receiving, The BER results are
satisfactory for different SNR. However, when i use two separate USRP for
transmitting and receiving, Then BER is .5 for all SNR.
Why it is happening?
Message 1 of 12
(4,650 Views)
Hi A87,
Can you shed some more light on the problem you are facing ? Can you please provide the details of the configuration of the USRP used for TX & RX ?
Plus if you are working with digital modulation schemes, have you ensured that you are providing the synchronization parameters for demodulation ?
If the reference pattern and the demodulated bits are even offset by a few bits, then you could observe this problem.
Some of the fundamentals of the synchronization while working with digital modulation schemes is explained in the forum post mentioned below.
http://forums.ni.com/t5/LabVIEW/How-to-use-Generate-Synchronization-Parameters-for-PSK/td-p/1763962
http://forums.ni.com/t5/LabVIEW/Generate-Synchronization-Parameters/td-p/2744418
Hope some of the above information is helpful.
Thanks & Regards,
Raghunandan N V
Application Engineer
NI - India
Message 2 of 12
(4,631 Views)
Hi mv,
I connect the two usrp by SMA to SMA cable for PPS Trig and REF.
And for synchronization, i am using preamble which is PN sequence.
When the received signal is correlate with this preamble, i get peak so that i confirm that actual data is received.
Message 3 of 12
(4,602 Views)
Unfortunately daisy chaining 294x/295x USRPs is not supported. I feel this might be the root cause of your problem. Are you doing anything else to ensure your USRPs are synchronized (besdies the cable wiring)?
Message 4 of 12
(4,593 Views)
No, I did only cable wiring.
is there any other option?
Message 5 of 12
(4,584 Views)
A87,
The best way to synchronize multiple USRP RIOs is to use an CDA-2990. This will let you distribute one external clock from a timing card to multiple USRP RIOs, or to generate a clock in the CDA-2990 and feed that clock to the USRP RIOs.
Message 6 of 12
(4,580 Views)
Can i do carrier phase synchronization?
Message 7 of 12
(4,574 Views)
What level of synchronization are you talking about? If two USRP RIOs share the same 10 MHz and PPS reference signals, they will have phase coherence,  but not phase alignment.
Message 8 of 12
(4,568 Views)
Hi, When i use Labview example of a QPSK i get proper constellatation without any synchronization.
For more clarity, i attached note and some gvi file
Message 9 of 12
(4,523 Views)
Hi
Message 10 of 12
(4,522 Views)
